james2747
- Jan 26, 2011
- Location
- Newent, Gloucestershire
- E270 CDI 2003
On my 'aged' E Class I have used 30 p.s.i. all round for my tyre pressures for years, as this is the recommended pressures from Mercedes ... well they actually state 29 p.s.i. for the fronts but I bet most garage air supply's are NOT even accurate to 1 p.s.i.
However, I never noticed until recently the +4 p.s.i. bit on the tyre pressure guide that is on inside of the fuel flap (see bottom left hand corner of the photo).
It states: "Warm tyres up to: +4 p.s.i."
Does that mean if tyre is warm I should set pressures to 34 p.s.i. ... or 26 degrees to allow for tyres heating up? And what does 'warm' mean? Is that a sunny summer day with air temps at 20 degrees centigrade and tyres 'cold' ... or tyres warm from running, after a drive in winter maybe, when outside temperature is say 8 degrees?
4 p.s.i. pressure variance ... on 30 p.s.i. tyres is quite a significant variance (over 13.3% to be precise).
I love the full load and high speed pressure recommendations:
I rarely drive with more than 2 up ... and I do try to keep my speed a little under 130 m.p.h. (my 2.7 litre diesel Merc, over 20 yrs old ... oh, I wish!!)
Any suggestions on the + 4 p.s.i. welcomed.
