Chas
This link might be usefull folks,
http://www.thetyrepressuremonitor.com/tyrepressures_mercedes.html
:smile:
:smile:
Blobcat said:Mine isn't listed, I find my fuel filler door covers mine quite nicely though
How are your valve caps by the waytelevision said:You should have had the auto tyre pressure monitor feature![]()
I don't even have to get out of the car:mrgreen:
Malcolm
Blobcat said:How are your valve caps by the waysomehting else to go wrong as far as I'm concerned. Unless of course I had them then they would be an essential feature
There is a small transmitter on each valve in the wheels, with the reciever in the car. you store the pressure from each wheel to the reciever. If one of the wheels deviates then the chime goes off in the car, "check front off side " .Chas said:How does the auto tyre pressure monitor feature work,and can it be retro installed on my S320 (2001) ??
:-D :-D
television said:There is a small transmitter on each valve in the wheels, with the reciever in the car. you store the pressure from each wheel to the reciever. If one of the wheels deviates then the chime goes off in the car, "check front off side " .
you still have to blow the thing up or fix the pucture, not sure if it is a dealer retrofit.
Malcolm
