Tyres and petrol consumption
51315
Canterbury
W247 AMG B200 (2020), A160 (2009) CLK270 (2005) SL230 Pagoda (1964, long gone)
If I under-inflate tyres by 2psi for a less bumpy ride (Goodyear Efficient Grip Performance) what % increase in fuel consumption will I suffer? Anyone?
Nothing you will notice buddy , go for comfort . What pressure have you reduced to ?
You’ll only be able to tell this yourself. If you track your fuel economy already (not from the dash) then drop the pressures and see the difference.
I can see the reduction in fuel economy from summer to winter tyres (there’s also the cold weather longer warm up affect)
51315
Canterbury
Reduced to 27 psi from normal 29 psi.
I don't know how much different cars and different wheels allow different pressures , but neither of mine would be under 30psi front and 32/33 rear.
Be interested to hear what anyone else thinks , it sounds a bit low at 27
That does sound a bit low. What size tyres are you running?
If you run them too low you run the risk of heat delamination in the sidewalls.
51315
Canterbury
For W169 - 2009 A Class 160 unladen pressure is 29psi front and rear.
51315
Canterbury
195/55R16 Goodyear Efficient Grip Performance 87H.
Petrol lid says unladen 29psi all round.
Ah ok 27 will be fine then. The bigger MBs run much higher pressures.
sonic
Staffordshire
E350CDI, SLC250d, FJR 1300
I see an improvement summer to winter tyres. But I change from 18" to 17".
I’ve never had an improvement going summer to winter as the rolling resistance of the winters is significantly higher than the summers.
sonic
Staffordshire
Defiantly better for me but only for a month after changing, when still not cold.
I normally change mid Oct & mid April. I am sure the smaller tyre makes the difference.
Dean Fletcher
Penrith, Cumbria
Mercedes E400
What size tyres do you have?
Gazwould
C250 CDI
Bumpy ride - renew dampers .
keefysher
Hampshire
W166 GLE350AMG Line 3.0 2017. BMW Z3 2.8 1998.
I normally change from summer tee shirt, shorts and Teva's to jeans, sweatshirt and trainers mid Oct & Mid April too. But keep the same tyres year round :cool::p;)
Dean Fletcher
Penrith, Cumbria
Mercedes E400
CLK , winters are 205 55 16 , summers are 225 40 17 front , 245 45 17 rear (ish ?)
E Class , 225 55 16 winters , 245 45 17 summers
Mine are 245/35/18 front and 255/35/18 rear. Rear is 36psi and 35 front. Its says if the car is fully packed put them up to 40psi Haha
