Ultimate OM642 build (2009 R320L CDI, 7G-Tronic)
ajlsl600
france
be
If you decide to rebuild it, grind in the valve seats and fit new valve seals, it would be false economy not to while the heads are off.
berfore u do that pour some diesel in the intake ports and see if valves are leaking then do exhaust , give you a good idea of, if ,where valve seat issues are.
G
Ge2tis
Grimsby
R320L CDI 2009, 3.0 V6, 7G-tronic, 207k on the clock
  • #42
be
Did that...no leaks but quite a bit of soot everywhere, especially on intake valves..
G
Ge2tis
Grimsby
  • #43
Update time...
So, yesterday was all about taking everything to bits... I took all the pistons out...then dismantled those..nothing seemed damaged except that most of the big end bearings had some markings (see pictures, shows very clearly). My brains comes to thinking that it was done by small metal bearing particles that were circulating when No.6 big end gave up.
As that was about everything that I could do with the block until I have that flywheel locking tool, I continued to take the heads apart...lifters and rocker arms put in the oil to keep them soaked. Then valves were taken out with a very decent Clarke tool (pictured), labelled and put in separate bags for when putting it all back together .I bought this spring compressor because I don't like the levered ones and this one made my life much easier. Recommended if you plan on doing something like that (disclaimer: I have no connections with Clarke or any tools manufacturer, just my opinion) :).
Right...that's it so far...unless someone could lend me a very strong impact gun to undo the pulley bolt...;)
Pictures coming your way... IMAG0233.jpg IMAG0230.jpg IMAG0229.jpg IMAG0228.jpg IMAG0227.jpg IMAG0226.jpg IMAG0225.jpg
G
Ge2tis
Grimsby
  • #44
More photos... IMAG0242.jpg IMAG0241.jpg IMAG0239.jpg IMAG0238.jpg IMAG0236.jpg IMAG0235.jpg IMAG0234.jpg
G
Ge2tis
Grimsby
  • #45
More photos.. IMAG0249.jpg IMAG0248.jpg IMAG0247.jpg IMAG0246.jpg IMAG0245.jpg IMAG0244.jpg IMAG0243.jpg
G
Ge2tis
Grimsby
  • #46
More photos... IMAG0257.jpg IMAG0256.jpg IMAG0255.jpg IMAG0254.jpg IMAG0253.jpg IMAG0252.jpg IMAG0251.jpg
G
Ge2tis
Grimsby
  • #47
More photos.. IMAG0264.jpg IMAG0263.jpg IMAG0262.jpg IMAG0261.jpg IMAG0260.jpg IMAG0259.jpg IMAG0258.jpg
G
Ge2tis
Grimsby
  • #48
More... IMAG0272.jpg IMAG0271.jpg IMAG0270.jpg IMAG0269.jpg IMAG0268.jpg IMAG0267.jpg IMAG0266.jpg
G
Ge2tis
Grimsby
  • #49
More IMAG0279.jpg IMAG0278.jpg IMAG0277.jpg IMAG0276.jpg IMAG0275.jpg IMAG0274.jpg IMAG0273.jpg
G
Ge2tis
Grimsby
  • #50
More... IMAG0285.jpg IMAG0284.jpg IMAG0283.jpg IMAG0282.jpg IMAG0281.jpg IMAG0280.jpg
That conrod in the top few pics will need replacing. The bearing has been spinning inside the rod and has damaged the rod.
Given that I would be tempted to get the rods balanced (the rod weights are equalised overall and end to end) before reassembly.
I'm also not sure that crankshaft will be reusable looking at the amount of damage.
G
Ge2tis
Grimsby
  • #52
More... IMAG0295.jpg IMAG0294.jpg IMAG0291.jpg IMAG0290.jpg IMAG0288.jpg IMAG0287.jpg IMAG0286.jpg
G
Ge2tis
Grimsby
  • #53
More... IMAG0304.jpg IMAG0302.jpg IMAG0301.jpg IMAG0300.jpg IMAG0299.jpg IMAG0298.jpg IMAG0296.jpg
G
Ge2tis
Grimsby
  • #54
More... IMAG0313.jpg IMAG0312.jpg IMAG0311.jpg IMAG0310.jpg IMAG0309.jpg IMAG0308.jpg IMAG0307.jpg
Incidentally - if you haven't marked how the caps go on the conrods then every rod will need replacing as the cap MUST go back on the same rod in the same orientation.
G
Ge2tis
Grimsby
  • #56
M80
Derbyshire
I think this is an interesting project and may become relevant to me, even if only in part.
With the time effort and money you're likely to put into this wouldn't it be a better option to pick up a pre owned engine?
Knowing the replacement is of good serviceable quality is the issue of course, you might end up with another duff 'en, even one that's been hydrolocked. But if the breaker can show a serious accident damaged vehicle that should reduce the risk.
G
Ge2tis
Grimsby
  • #59
I did...every single one... :) however I am trying to find anyone that would have a set of new ones in stock or could make one..as mine do have 180k and might not be suitable for another 180k that I plan on putting on this engine..:)
I found one company in Germany that has OE for around £260 per set with postage...but I have my doubts...I much rather pay a bit more and have it sourced locally...I asked a dealer and their price is £199 each...not the kind of money I want to pay for that..:(
G
Ge2tis
Grimsby
  • #60
That's exactly my concern about buying a second hand engine from someone...I could end up with same problems anyway...I much rather spend a bit more and do it my way knowing what's been put inside...and looking after it as it should be done...:)
  • Like
Reactions: M80
