EddieHarrald
- Aug 22, 2018
- Mercedes E320cdi
- Thread Starter
- Thread starter
- Banned
- #21
Thankyou! I will pass your Comments on to the Garage on Monday !!How much the drain current is?
One not fused place is breather heater, should be rather easy place to unplug and test.
I recently read memory seats would have two voltage feeds, where another one is not fused, so unplugging seat fuse wouldn't isolate the draw if another circuit is faulty. I have not yest verified if that's true.
Electric heater boosted in air duct draws huge amount of current if short circuited and is easily seen in current reading.
Have you got yor aux battery isolation relay checked? If aux battery is again bad and relay jammed, it will draw main battery.
How much your alternator is charging. W211 have couple of different specific regulator packages, and wrong type is not communicating with car (though it should not cause draining and limp mode charge is 14,3V constantly).
No aftermarket radio, or alarm fitted? No dash camera?
Does anyone know if A Mercedes Diagnostic Computer, Will detect the Fault ??
