Unusual Tyre Wear
Alastairp
West central Scotland
2005 CLK200 coupe (now gone) 2011 R230 SL350 2014 C220 estate
I have noticed that the outside edges of both front tyres are very worn.
Vehicle is 2005 CLK200 with just under 48,000 miles.
And rear for comparison purposes
Any help/ advice appreciated.
Alastair
FlorinM
Cheshire
2014 C250 CDI Amg Sport Edition (Premium Plus)
Those fronts look really bad.
You should go for an alignment check, and probably some new front tires.
DSK
CLS 320 CDI, S350 Bluetec
Wheel Alignment would be the first step.
I would also not discount worn suspension components even if they are not picked up at MOT time.
How many miles has it taken for that to occur?
Larkone
NW Essex
C219 CLS 320CDI 2008
When they do the alignment check ask them to check the castor and camber angles - not just the toe in.
grahamcol
West Midlands
2001 SLK230, 2007 CLK220 CDI
Yes, full alignment check probably best.
Having said that, every Mercedes I've ever owned seems to have that type of tyre wear. However, the pics the op has provided do seem to show extreme shoulder wear.
Looks like excessive toe in to me. There appears to be evidence of feathering on the sipes.
Generally worn suspension causes wear on inner edges of tyres.
As above, full hunter tracking will show any issues.
A
Alastairp
Update:
Indie wanted new tyres fitted before doing steering geometry check which I have done.
Steering geo was checked by indie when in for 48k service yesterday.
Said it was pretty good with only the tiniest adjustment necessary.
All bushes & joints checked and reported to be sound.
Just to monitor wear going forward now.
Btw, it drove absolutely fine, just the wear on the outside edge.
tavernole
Bournemouth
Mercedes S320 Cdi 2007 W221
Update:
I would still go for a full hunter wheel alignment tracking check
