Hi All,
With the recent changeable weather, I can report that consistently on days when the temp is below 10 degrees celcius, the ML idles at 1400rpm until warm, and behaves faultlessly, ie idles at 700 rpm when outside air temp is warmer. Battery, throttle pedal unit and ECU all changed by MB under warranty. Hope this helps the experts out there.
Many thanks for your help so far, anything spring to mind Malcolm (TELEVISION) ?
Best regards
Best regards
