urgent desprate help!!!
pdn1
hi guys newbie here!! ive got a problem i owen a 310 sprinter on a t reg/99 over the last few months its developed a cutting out problem whilst driving without any warning it doesnt give any warning at all I can be driving along then the edc light comes on and 1-2 seconds later i lose all power and get full dash board lights i then turn the key to off count to 5 and turn on again ai first it was once in a while but of late it has been 6/7 times a day i was told it was the battery so got a new one but nothing has changed any help would be greatly apprehseated the only time it doesnt cut out is on the motorway
D3AN
West Midlands
Mercedes C180 Esprit
By battery there is a plastic bag attached to the battery carrier (contains the wiring for the fuel pump), just make sure that isn't full of water/ terminal corrosion, if thats free of water and corrosion, then check the condition of the wiring to the fuel pump. Could be any number of things but thats just the common things I've seen that could cause your problem.
P
pdn1
will check that 1st thing tomorrow im at my wits end and not very good with engines
nickcc101
Helston Cornwall
Don't know much about the sprinter but on other diesels the fault could point to the injection pump solenoid. When you turn the ignition on this activates the solenoid and allows the engine to start, when key is turned off this cuts off the fuel stopping the engine. Usual fault is either poor connection to or at solenoid or faulty solenoid.
P
pdn1
will check that sounds plauseable to me
P
pdn1
checked the bag and its in perfect condition
D3AN
West Midlands
Just a thought, the wiring to the needle motion sensor (injector with the wire) would also check that wire..... I believe potentionmeter can also cause this problem, I guess when all the visual observations have been done, probably be a good idea to get a diagnostic report.
D3AN
West Midlands
The crank postion sensor is located above where the startermotor is bolted to the engine. Can't visually check the crank postion sensor as such, unless the wiring is shorting somewhere, or something has given it a clout from off the flywheel, which I've only ever seen once and that was on a cdi engine. With a meter you can check the readings, but it's an intermittant fault you have and easier to let the diagnostic machine look for it, if it's an electronic fault the machine should diagnose it.
P
pdn1
i think your right will find some where local that can do the check and will post back diagnosis
