John Turner
- May 20, 2002
- S124 250TD (1989), S124 E300TD (1995), S211 E320 cdi Sport (2007)
If any one can help asap - preferably before dark, it would help!!
Car is W124 300TD. Following flat battery, charged up and replaced but nothing will work - not even lights. Battery reading good. I cannot find anything wrong except the short lead from positive terminal is not attached to anything. This lead is about 20 cm long and ends in a metal eye, which I assume should be go over a bolt. I did NOT undo this lead from anything, and yet cannot believe that a positive cable should be lying loose. There appears to be nothing within 20cm of battery that is obviously missing a lead!! The electrical connections to the connection unit sitting on the suspension strut top are all intact. Is this why the electrics are totally dead? Where does this lead go? Can anyone help, otherwise I cannot get to work tomorrow!!!
Many many thanks
Many many thanks
