ebony266
just removed rear bumper of a 96 w210 saloon now the boot lid will not open ????? light on the bot button (inside ) stays on ?? please help tools in boot !!!???
should i cisconect the bat
yes and all fuses
Did the same thing a while back having closed the lid with the plastic trim covering the boot lip removed thus not depressing the switch in the lid fooling the electrical circuit into believing the boot is open therefore making the release switch in the car inoperable.
It is possible to release the boot lid lock with the key but it is not a 'do it once and all is well' it took me over 30 min to get the thing to release. What worked for me was pushing very hard on the key with a pair of long nose pliers to push the barrel as far as possible into into the lock mechanism to release the lid, you do have to persevere though.
Yes the above is true and when done its worth getting the little plastic key blanks that keep the water out
Ah Ha is that what is causing my boot lid to fill up with water
:sad: no joy
I have some reasons for that, what are the first 6 vin numbers
sorted !!!!!!! had to remove speaker housing (parcel shelf )split foam ?? find plunger with a stick ?? then depress plunger and got daddy to press boot button !!! thanks all and thanks daddy
hi Malcolm, any info for me?
Yes re the charger,,they give out 18volt when the battery is not plugged in.
If you would like one I can send you one that works
