SteveX
- Oct 27, 2009
- Thread Starter
- Thread starter
- #61
Sometimes I amaze myself, all working. I decided to strip the old sealed unit apart and see what made it tick.
So I carefully took apart my old sealed unit, and upon striping it down realised that the sensor which was missing from the replacement unit was removable (as was the shaft that has the keyless go power and signal feed). I decided to take the other one back out of the car, and I ended up retrofitting the keyless go shaft and the keyless go sensor to the unit I bought from the Merc brakers that was fully working and guaranteed
I have a table of carnage but I now fully understand how they are put together. Essentially when I called Mercedes today they wanted £512, when all I needed was to replace a small plastic box with a gear and sensor in on mine. It's literally a generic part, the one I got from the C class is the same, even has keyless go power output and signal.
The base unit had the fitting point to mount the keyless go sensor to that detects when it is in P and can activate, and the case had the pre molded gap for the external plug to go into for the sensor fitment.
Quite chuffed, normal service has resumed
So I split an A209 267 03 24 and retrofitted it's working parts to an A203 267 60 24
Thanks.
Thanks.
