USB Media
Doors
GLA 2020 200d
My music is MP3 files on a USB memory stick. It works just fine with everything I have so far plugged it into. However MBUX does not seem able to find it.
Anyone know if MBUX can play music from such devices, does it need any special file arrangement/ protocols etc ?
richlumb
GLC 350d
Try a different usb memory stick and check the manual For what format your usb needs to be set at
Chrishazle
Nr Ashford, Kent
Possible that the USB stick needs to be formatted Fat32 for the MB system to read it.
Jim2
1st Merc 2010 E Class W212 2.1 CDI. 2nd Merc 2014 E Class W212 220 CDI 3rd Merc 2018 E class W213
I transferred some music from the computer on to a micro-sim with use it with an adapter in the slot on the dash near the radio controls, and it works fine. But in the centre console between the two front seats, there is a USB connector and it seems to be for connecting a USB stick to the Sat-Nav., or. something else associated with the Comand set up...Can anyone tell me what this this is for? ( there is a second connection in the same console, but it seems to be for a phone, and it s not a USB connector ) )
s5tuart
2003 R230 SL350
I formatted mine to EX-FAT and my car won't read it.
I'll try FAT32 :D
s5tuart
2003 R230 SL350
I use that USB slot to connect my phone for Apple Car Play for music and for the Waze sat nav on the phone
D
Doors
GLA 2020 200d
Have found a solution -
First of all what I was using is a USB / SD converter. It is a USB device that you can plug a micro SD card into so as the card can be read through a USB port. I have a couple of these and have never had any bother using them, can plug them into my van, my last car, the hifi in the house and even the TV - and have no problem playing the music files. But it will not work on Mercedes MBUX
Went into the dealership and one of the technicians took a look and told be it was because of the SD Card and that it would only work with a USB Memory Stick. Had no explanation other than SD Cards just don't work in Mercedes
So on returning home I borrowed a memory stick from a neighbour, plugged it in, and hey presto it all works perfectly.
As they say we learn something new everyday, and for me it is memory sticks and USB SD card readers are not the same thing.
Jim2
I use spotify connected via bluetooth for music ( but it has a CD player built in + Radio )so audio is pretty well looked after. The USB I thought has another function, connected to either NAVI ( memory for remembered routes? ) The 2nd connection slot is definitely for phones though,,,,,there were 3 different adaptors in the console, for 3 different makes of phone. When you plug in the phone to use WAZE, does it show up on the car sat nav screen?
s5tuart
2003 R230 SL350
yes it does. I have Command and when Apple Car Play is Active the built in car screen displays just as my iPhone does. One can then select the icons to suit
richlumb
GLC 350d
If you said from the start you was using a adapter I could have told you it doesn’t work :)
D
Doors
GLA 2020 200d
Up until yesterday I thought they were two of the same. But clearly they're not.
Botus
S500/2010/500
what's the card?
sd uc ? if so not surprised, sd xc maybe, and if its sd hc I would have thought the right formatting it would work
D
Doors
GLA 2020 200d
what's the card?
32gb sd hc - fat 32. Works absolutely fine as a memory stic substitute on evrything I have tried it in apart from MBUX.
It makes little difference that it does not work in the merc, cost me a few quid for a 'true' memory stick and the MBUX system works wonderfully with that. And the voice command to select whatever track or artist I want to listen to is also pretty dam good too, but that is may be for another thread.
Marian38
Mercedes-Benz GLA/2017/200D SE
Hi, I have a Mercedes-Benz GLA 2017,200D SE, and im trying to use sd card and USB, neither of then recognised by my car....(sd card it's 256gb fat32 formated, USB is 2T fat 32 formated) USB tried in both ports, neither working....I don't know what's the problem.
mattkh
England
A160 W168 1999 1.6
Try a memory stick.
Srdl
New Forest, Hampshire
GLC43 AMG 2018 (X253)
I’ve got a feeling the memory size of your SD and USB may be too big for the Mercedes system. I can’t find anything specific in my manual other than this statement:
The multimedia system supports data carriers with up to 50,000 files.
In the case of a data carrier with more than 64 GB of stored data, only files in folders with the following names are supported: Music, Pictures, Video.
This seems to imply that if your music is not in a folder called “Music” the system can’t recognise it.
Marian38
I've tried to put movies ,video clips and songs in folders called movies,clips,music and doesn't work, then I've tried to put everything without folders ...same thing ,didn't worked. I'm thinking is about formatting my sd card and USB, maybe needs them specified formatting.
Ericmacv
New Registration
Southampton UK
C200/2.0 Petrol/2018
SOLVED !! I had the same issue and solved it. Inserting a USB device will do noting until you go to devices and authorise the device. Using FAT32 with no folders I was able to play MP3 and the audio from MP4 files with no issues. So.. to summarise, you need to add the USB stick as a device. ( device is one of the options at the bottom of the screen)
Tel: 020 8863 9233
