v220 cdi reverse lights
hmang
guys i've posted about this before but it's getting more urgent now as it'smot time.
i'm still trying to locate the reverse light switch on my 2003 v220 cdi.
any clues or ideas why both lamps have packed up
BlackC55
South coast
C43
It may not have a switch. It maybe electronic (inside a control unit)
H
hmang
thanks black
i don't think i wanted to hear that news.
jibcl500
Cambridgeshire
CL500,ML55,SLK280
isnt it a switch on the gear shift, center console.
jib
H
hmang
that's what the parts man at dealers called me back to say.
but i can't see anything that actuates when reverse position is selected
jibcl500
Cambridgeshire
CL500,ML55,SLK280
it could be deep inside the auto selector, have you had it apart?
jib
I will find it for you later in the day
H
hmang
jib
jib:
no not yet. just a look around the outside.
there are a couple of switches on the left side of the housing but neither seem to correspond with reverse.
there doesn't appear to be a lot down inside the skeleton of the housing and no wires seem un accounted for.
by auto selector , i'm assuming you're referring to what i'd call the gear lever housing on the dash.
and:
thanks malcolm i'd appreciate your efforts
H
hmang
the switch is on the gearbox....about the size of the palm of your hand.
undid the 2 bolts and disconnect the cable at the splined shaft
don't worry about getting it back in the right place 'cos it's located by 2 flats.
drilled out the rivets ..7 off...split the cases and clean up the corroded contacts.
re- assembled with 4mm nuts and bolts instead of rivets...bunged it all back on, and job's a dream.
hope this helps any one else.
thanks guys
thanks guys
Thank you for posting back, at least you can see what you are reversing into now :cool::cool:
H
hmang
you've obviously seen my driving malcolm.
it should be the subject of another post..." clonking noise while reversing..."
well if they are going to put lamp posts so close to the road they've got to expect some casualties haven't they !
The static ones are OK, it is the mobile ones that get you.
In Sweden you do not have lamp posts along the kerb, they are always on the inside of a pavement
H
hmang
Pah!!... i could hit them...no problem !!
