v230 air suspension
19eddie82
ive recently bought a 1997 v230 petrol and every thing was fine for the first few weeks and suddenly the air suspension has packed up. its stuck in the lowest position and the body is rubbing on the tyres, if i press the button on the centre console the light on the dash flashes but nothing happens and once i let go of the button the lights just stays on.
ive read a few posts on here and realise this is a bit of a common problem and was wondering if anyone had any advice. i know alot of people swap for springs, how easy is this and how is it done and is its easier to fit a new motor or fix the original.
also how do i check to make sure it is actually the compressor/motor as i dont want to change them for no reason.
thanx in advance for any help
Eddie
alanuk400
Belfast NI
www.vipsec.co.uk
2018 W222 Mercedes S-Class LWB & 2006 R171 SLK 55AMG
19eddie82
so judging by the diagram the air cushions stay where they are and the springs go in aswell?????
alanuk400
Belfast NI
www.vipsec.co.uk
No, when you get it up on the stand you will see that the air bags have No 8 attached as part of them, make sure the air is out of them, its easier to get to the bolts (as far as I can remember). I just cut the airlines and took the compressor fuse out.
Alan
19eddie82
so i need everything that youve listed there?? Sorry to be a pain but dont suppose you have any MB part numbers. I think ill be tackling the job during the week so ill more than likely be back on here for some advice once i start.
Cheers again for all the info.
eddie
colinv230
New Registration
v230 air suspension problems
Have been reading these posts. It sounds like this is a common problem. I had the suspension light staying on on my V230, and I was told by the garage that the bellows were leaking (fairy liquid test). I had them replaced for £400, and the suspension now stays up overnight. But if the car is left for a couple of days, the suspension is right down at the back. When this happens, I switch on the engine and it takes 15 minutes for the car to start pumping the suspension up. The light stays on during this time and the suspension shows no sign of moving. After 15 minutes the light goes out and suspension is up a fraction. Does this mean that the pump is knackered as well, or that something electrical has blown? (Should I just look for a garage that can replace with springs??)
matthewm1965
Durham
1999 W220 S500L, Toyota Supra Mkiv, 1970 Triumph GT6
Probably the pump that is failing.
I recently had a quote of £400 to replace the pump.
Cole@MBS
www.mbssouthampton.co.uk
Why pay £400 for a pump when you can fit a spring kit for just over £300 and never have to worry about any of it failing again!!
matthewm1965
Durham
I didn't realise the spring kits were so cheap.
