I am after a vacuum diagram for a 1991 230TE fitted with auto box and Katalyst. I am quite willing to pay for it, be it in book or sheet format, as along as it relevant to my car, so a Haynes manual is not what I am after
I had a similar problem! None of the Haynes, Chilton and/or similar repair manuals had the correct diagram. I was able to obtain the correct diagram from a Mercedes Benz parts supplier: the computer/software the is provided to the parts dealer by from MB will have the diagram... ask them to be kind enough to print it for you. Usually the drawing will show 2 or 3 diagrams for different models that use the same carburetor but perhaps have different engines, so make sure they indicate the correct one for your vehicle!
Please advise if you were able to solve your problem!
I had a similar problem! None of the Haynes, Chilton and/or similar repair manuals had the correct diagram. I was able to obtain the correct diagram from a Mercedes Benz parts supplier: the computer/software they are provided with by MB will have the diagram... ask them to be kind enough to print it for you. Usually the drawing will show 2 or 3 diagrams for different models that use the same carburetor/fuel injection system but perhaps have different engines, so make sure they indicate the correct one for your vehicle!
I had a similar problem! None of the Haynes, Chilton and/or similar repair manuals had the correct diagram. I was able to obtain the correct diagram from a Mercedes Benz parts supplier: the computer/software they are provided with by MB will have the diagram... ask them to be kind enough to print it for you. Usually the drawing will show 2 or 3 diagrams for different models that use the same carburetor/fuel injection system but perhaps have different engines, so make sure they indicate the correct one for your vehicle! Make sure you provide them with your ENGINE NUMBER!
Comand Online Ltd is a specialist supplier of Mercedes Navigation Disks,
Phone & Bluetooth, iPod, DAB, CD and other COMAND retrofit parts to
enhance your vehicle.www.comandonline.co.uk
