Helicopterrob
- Sep 15, 2006
Hello,, thoughts and suggestions on this one would be appreciated.. We have an 03 mercedes vaneo ambiente 1600 auto with cruise etc... The engine management light shows and alerted us to a problem, the fault code comes as P0120 Throttle Pedal Position Sensor/Switch A Circuit Malfunction,, we have replaced the throttle sender to no effect and we do not think the problem is in the wiring as we can drive the vehicle perfectly OK providing we do not depress the accelerator more than fifty percent. ( the wiring positive and negative to the switch is OK and there does not seem to be an open/closed circuit on pin 5 of the plug.) As the accelerator is depressed more than fifty percent the esp and bas switches off and the vehicle goes into limp mode until we switch off and re-start. This happens whether the vehicle is stationary or moving and makes not difference whether it is in neutral, park or drive or whether we have switched of the bas using the dash switch for doing so. The vehicle can be driven perfectly on the cruise control across the full rev range and at all speeds and the fault of switching off only comes with the use of the accelerator.. On-board voltages are fine, we have cleaned all the connectors we can find and we are stuck on this one... Mercedes main dealer have no idea and other independents show just the same code as us. 1) Does anyone think it may be an ecu fault and given that we understand the ecu on this is combined with the airflo manifold ? are there any other boxes of tricks that we may not have found wanting their connections checking ? Thank you
