vario 814 indacators
farrellniall
New Registration
dundalk co louth
mercedes vario 814
hi new to this :)
i have a mercedes vario 814 99 school bus.
i am having trouble with the indacators!!
they will work but they will not show up on the dash board and you cannot hear it clicking behind the dash.
can any one shead some light on this for me.
thanks.
Roxie
Lincolnshire
C Class 350CDI 2012
The indicators flash from the ground module pulsing. The clicking is just an audible warning that is generated by the instrument cluster.
So I would suggest that you have a problem with your instrument cluster or perhaps a power supply problem with it.
Does anything else not work on your display?
vauxhallmaniac
SL350/SLK320 Special Edt/SLK320 "Tinkerbelle Edition"
Pop the dash out its only a few screws and check the printed circuit if you locate the indicator bulb in the dash and trace its track there will be a break its common for the tracks to detiorate on the 814, i soldered mine for the indicator telltale and its was fine for years :D
