Webcentre
Just wondered if anyone can help, ive had a search but none of the problems are quite the same as im suffering.
Basically, 1992 190e, 2lt 150k
Problems:
Windows mist up if left for over 2 odd hours, regardless of weather. Now im guessing that water is accumilating somewhere but i cant find any. looked under back seat swab, front footwells etc. Are there any common places that water accumilates, say from blocked sunroof drains possibly?
Secondly the car sits at 4200rpm at 80mph. this seems a little high to me and gives rather loud crusing, is this the correct amount of revs for the vehicle?
Cold start problems. Vehicle starts if u accelerator is floored, will not start without accelerator. Will not idle or run below about 2k rpm, but if held at 2k with accelerator until warm, engine idles and drives perfectly. After reading around could it be the cold start valve with the bimettalic strip, if so, where is it? (not the supplimentary air device or the injector, the little item that controls these)
Windscreen wiper problem. The wiper will park randomly on the screen when used on intermittant setting. never stops in the same place, but if u time it just as it starts its arc and turn it off, it will park in the correct place on the opposite side of the screen, if u see what i mean. I.e the time it operates for seems to be correct, but something else is amiss
Cruise cnotrol has packed up. Wil not keep to a speed, once set, it operates for a few seconds the turns off. Been reading, could be brake pads being low but any other suggestions?
Sorry for the long post, any help would be much appriciated.
Cheers, Mat.
Problems:
Cheers, Mat.
