Very best oil for 99 c250 td?
Ad777
1999 C250 TD estate W202 engine
Hi all, I want to treat car to a really good quality oil change. Have searched all the oil checkers, and there seems to be a lot of variation in suggestions.. from 0/40 to 5/30 synthetic. Any suggestion as to which make and grade would be best? Sitting at 115,000. Many thanks
ajlsl600
france
Use midrange recommendation in yr owners /guide. And if u want to "treat"yr motor do changes at half intervals .
A
Ad777
Thanks..I do very regular changes, but just not sure of best grade and make, just use what factor gives me. Don't have manual..Any suggestions?
ajlsl600
france
Get online and get copy of mb recc for yr motor then choose any that meet the spec laid out mb 229 .3 or whatever they say .the one I put here is NOT added here as yr spec think u are 0M651 engine ?search from that if correct .
No it’s the older (And more reliable) OM605
I wouldn’t be using a really thin oil in it. 10/40 is what I’d be looking for
A
Ad777
So would you say there is any advantage to spending money on the likes of castrol edge, or is that just a waste of money!
As per above just change it twice as often if you want to look after the engine
onefortheroad
uk.
Me -2019 GLC 350 coupe AMG line. Mrs- 1.2 vauxhall Corsa 2021 ,orange with a black roof. .
On paper a waste of money if your going to only drive half of the amount of miles, look at a 20 litre bag in box mercedes oil on ebay , or shell helix . If your doing 6 month oil changes.
A
Ad777
Thank you both.
A
Ad777
Thank you!
A
Ad777
So...10/40 or 0/40...what is the difference!
The difference is how “thin” it is at low temperatures.
With modern right tolerance high performance engines the lower (0W) is required. Your 1999 engine does not require such an oil and will use oil so you’ll end up tipping the oil up as the engine burns it as it’s not made to the same tolerances.
0w-40 is also a lot more expensive and you’d be much better served buying 10w-40 and changing twice as often.
Gazwould
C250 CDI
A 10W40 is more commonly found as a lesser semi synthetic and 5W40 a fully synthetic with all it's benefits .
0W30 to 5W40 is actually listed by Fuchs and 5W40 to 10W40 by Opie Oils , somewhere in the middle of everything is good .
Go 5W40 fully synthetic .
mioba
Nottingham and Köln
My w124 has been using mobile 1 from day 1 till today as the recommended oil. Still does today and doesnt use a drop and engine is clean as a whistle. depends on the condition of engine re oil usage.
mattkh
England
A160 W168 1999 1.6
Very interesting.
Nobody mentioned an engine oil flush as a treat for the engine. Any views.
A
Ad777
  • #20
Yup...Have heard of a lot of negative outcomes from flushing. Thank you all very much for your input, have a much better understanding now. Appreciated!
www.ckinsurance.co.uk
