Not-a-mechanic
- Feb 19, 2020
- Viano 08 3.0 v6
Hi, if anyone can share some light. I have a 2008 viano 3.0 v6. 170,000 miles on it .
Previous owner 1 year ago put a new turbo on , I have since change oil, new transmission , air filter , fuel filter, new maf sensor and two new turbo pressure sensors.
it still has a problem. Even merc dealer couldn’t find the problem.
the problem is when I am driving at speed. 70 mph and holding for some time on the motorway then I go to either accelerate or slow down down then accelerate it has a loss of acceleration . You put your foot to the floor and it will creep up to about 80 after a minute or two as long as no hills are around. It is an automatic . The mechanic though the transmission was the fault but it is still occurring. This problem sometimes occurs when going at low speeds as well . Some days when going around town it hesitates a few seconds too long to speed up then goes like a rocket .
no check engine lights at all ever. No smoke. No knocking .
doing research I have checked play on turbo and seems to be fine . The inlet tube rubber seal is a bit mashed up and provides a pretty good seal with the clamp and pipe.
Should be checking the inter cooler pipe? As I’m not sure if this was changed when turbo was replaced? Accelerator sensor? throttle pressure sensor!
does anyone know of any tests I can do ? Or anyone have had the same issue.
Any help or advice would be appreciated.
