VIANO ELECTRIC SIDE DOOR
Steve Worrell
VIANO 2.2CDI EXTRA LONG 2011
Good Morning all.
I have a 2014 Viano with a problem with the electric sliding door on the drivers side.
As it opens it gets 75% of the way then does a little jump before it opens fully followed quickly by the door open bleep. The bleep is a warning that the car is moving with the door open but it's actually not moving at all!!
It's not a major issue but as I'm a working chauffeur it's just annoying.
I've adjusted the top and bottom hinge bolts without success but I've a feeling there is an adjustment point somewhere to restrict how far the door opens as I think it's opening to far then jumps slightly back but I'm not sure where it is.
Any help or advice would be much appreciated.
John jack
Viano diesel 2.2 cdi ambiente auto 2012
Good Morning All , I have a 2012 viano ambient lwb and the electric drivers side door keeps opening and now it won’t close, any ideas ? TIA John
Steve Worrell
I had a problem with my door which kept trying to open to far and jumped slightly.
Out of pure luck I disconnected the battery for another problem and after it was reconnected it cured the side door issue!!!!
Worth a try.
Could be worth a try.
M80
Derbyshire
To avoid resetting all other functions you might pull the 2 under bonnet fuses.
On mine they were 27 & 28 on F34, F34 is the foward right fuse bank.
John jack
Worth a try.
www.ckinsurance.co.uk
