josepherely
- Jun 17, 2006
Have an unusual problem (I hope for Mercedes sake it is unusual) with the rear torsion bar on a Viano Ambiante (with air suspension), medium wheel base 3.2L. The anchor for the torsion bar has been torn out of the body/chassis on one side leaving that side of the bar dangling and hitting on the rear drive shaft. Obviously whilst doing so it doesn't serve its design purposes, let alone the drive shaft interference. When I say torn out it would have required considerable force to leave as much damage behind on the chassis. I can't see any mechanism for why the mounting (not the bushes) should be able to be pulled out. I have had a lot of problems with the build quality of the chassis and lose fittings, it could be that this was fitted loss originally allowing it some movement tolerance? The car/van is just 2 years old, 50,000 KM and has not been abused or heavily loaded. I have a photo if anyone is interested or could help give clues? Apparently they will have to replace the chassis components. I hope for Mercedes it is just a fault on my car and not a design/build problem as it could be an expensive recall issue for them. The rear suspension had been creaking for quite a while, and only in the last month or two really banging, so likely that came lose and then completely torn out.
Also interesting to know if you feel this is warranty issue or user damage?
