Vibrating and Cruise control problems
Otcik1980
Mercedes clk320 w209 2004
Hi I have Mercedes clk320 w209 124000. I have a problem with vibrating engine or gearbox I’m not sure but when I’m starting the car it vibrates I can feel it’s coming from middle of car. The second issue is when I set the cruise control it works fine but when I’m trying to reduce the speed moving the stick it’s going to fault and when I turn off the car and start again it’s again okay but as soon as I try to reduce the speed it’s going to fault again can anyone help please. Thank you
grahamcol
West Midlands
2001 SLK230, 2007 CLK220 CDI
Welcome. The vibrating might be because the engine and / or gearbox mounts are past their best. I can’t help re the cruise but I’m sure someone will comment soon.
Cruise going out could be a different size tyre/wheel - low pressure in a tyre can be enough to give a sufficiently large speed imbalance (as picked up by the ABS sensors to knock the cruise off
O
Otcik1980
Thank you for your reply I really appreciate it.
mattkh
England
A160 W168 1999 1.6
Interesting.
Are there any other signs/symptoms, when driving the car, of this speed imbalance..?
Interesting.
Tyre could be warmer than others due to more sidewall deformation. Pulling to one side if it’s a front wheel.
Not necessarily vibration as it could be balanced
