Vibration sound when in Drive position.. smooth when in Park position...
khnglh
Hello all..
i got a questions i hope any kind soul can offer me some advice. i got a 1994 c180 w202 automatic which drives beautifully but i recently noticed the following problem (or i think it is a problem..hmm)
when i cold start ... the RPM goes to 1000 and stays there for a while before dropping to approx 600-650.. (this is normal as far as i know).. however when i put the gear into Drive with my brakes on.. the RPM drops a bit and the car starts making a vibration noise near the right aircon vent.. however when i push the gas down or start driving .. the sound is gone.. it starts again when i stop at a traffic light. this happens also in reverse.
Any suggestions ? i remember reading about changing the engine mounts, tunning, changing sparkplugs.. any thing else i can do...during my next service ?
All information appreciated.
Cheers
JK
K
khnglh
the mounts looks worn and abit crack... that could be the cost of it right ? also.. do i need to change the absorber thingy near the fan at the same time ?
There is no connection between the 2 faults, just do the engine mounts for now
Parrot of Doom
Manchester
Failed engine mounts on mine I'm pretty certain were also the cause of the belt tensioner shocker going regularly. Since I did the mounts, the shocker has been pretty much fine.
K
khnglh
its fixed!! as suggested in the posts above...
thanks all for your advice.. i got 3 of the mounting changed.. 2 for the engine and 1 for the gear thingy... now my car runs without any vibration :)
thanks
JK
