Viseoo / samsung phonebook issues..
DSB SL AMG
Cheshire
300SL (R129 1992 Pre-Facelift), Volvo V70 D5 SE Auto
Hi All,
At long last have connected the installed viseoo Bluetooth to my Samsung galaxy S3 phone...all ok except when I search my phonebook, a lot of my phone contacts are missing, sim contact's maybe? any ideas?
Car 2004 W211 E55k AMG
Thanks,
DSB.
DSB SL AMG
DSB SL AMG
Cheshire
  • #2
any ideas guys?
Oarsman
Norfolk
W221 S350L CDI Bluetec, Range Rover Vogue SE 4.4 TDI, 1963 Triumph TR4
IIRC you need to copy all contacts to the Sim Card and then complete a transfer.
DSB SL AMG
DSB SL AMG
Cheshire
this needs confirming...do I copy contacts to SIM or phone???
DSB SL AMG
DSB SL AMG
Cheshire
did a bit of research... max contacts
Software A: Phone Memory - 256 Contacts | Sim Card - 100 Contacts
Software B: Phone Memory - 400 Contacts | Sim Card - 100 Contacts
Also possible issues...
Why does my Sync light keep flashing/Why are my contacts not being displayed?
Synchronisation with your phonebook can take longer if you have alot contacts. Let it continue to flash until it goes a steady green. Each time the sync light flashes a connection is being established between your phone and the ViseeO.
Once it has gone steady green press the second button down on the ViseeO and your contacts will be uploaded to the Comand (this should happen automatically anyway). The initial syncronisation process is the longest and in some cases can take up to 5 seconds per contact number.
If the sync light contrinues to flash for over 30 minutes then this normally indicates that the ViseeO is having a problem synchronising the contacts. Problems can be caused by + in front of phone numbers (i.e. +44 870). E-Mail addresses or Home/Work addresses can also cause issues. The ViseeO is designed to read a name then a number so any non-numerical characters within the number part of the contact itself can cause issues.
So first thing will be to download contacts to phone memory...then check if I have any with +44 etc, will let you know update...
www.ckinsurance.co.uk
