Vito alternator - help please!!
chrisandsam
Hi all.
I am struggling to find out some information concerning the alternator fitted to my vito 112cdi i need to replace it but it appears to have a pump of some sort on the back of it, does anyone know what this is and is it removable?...its a bit of a tight squeeze in there and i cant see whats going on! many thanks chris:D
Hello and welcome,,it is a piggy job to do, and a drive shaft has to be removed.
I can send you the 4 papers on doing this
C
chrisandsam
Thanks Malcolm, that would be great.
Thanks for the advice! So, do you know what the pump thing is that is attached?
The copy that I have is for the 111 engine Vito.
I will print off the diesel version in the morning, I do not know off hand as these are not my line,,Will know more in the morning
Quick Silver
Moonshine Island, surrounded by water
R129 1990 SL 300..
Hi all.
It's the vacuum pump
C
chrisandsam
Ta Quick Silver - that explains it!
I've spoken to a few local merc dealerships/good parts places but no-one could let us know if the part they could supply had a fitting for this pump - in fact most thought I was mad!
I'm pretty confident I need the 120 amp version - can anyone give me the proper part number I need please?
I am wide awake now, and will post back shortly with the info that you need.
Its best I think if you ask any Bosch service center to re con your existing one
I have the 3 papers for you.
Removing belt
removing alternator
Fitting a new regulator.
Its an easy job
GL MOBILE REPAIRS
New Registration
Wiltshire
Merc Vito 112CD1 2001
Hi I'm new to this forum. Unfortunetely my alternator has started whining like hell. My vito van recently went in for a fuel pump replacement. I was hoping this was the source of the whining. Not. The garage has informed me that the alternator requires changing at a cost of £300. Is this about right or is this job ok for a DIYer?
Thanks in advance of any info
Gary
Quick Silver
R129 1990 SL 300..
Gary
Its not to bad a job to do, but £300 sobs sounds a bit steep, cost of an alternator is around £160 using a bosch replacement. If you have an a/c unit then you must make sure you 've got the right alternator as they are smaller,the standard one won't fit AS IT IS BIGGER IN DIAMETER and length. On the back of the alternator is your vacuum pump if its a diesel engine.
Hope this helps.
Quick Silver
R129 1990 SL 300..
Hope this helps.
Please ignore what I said above I'm thinking of the starter motor with referenceto the size and position, the alternator is of course on the opposite end of the engine ref to the cost and DIY ABILITY is correct.
johnbollard
ireland
vito 111 cdi
could you send me these papers aswell merc vito alternator
could you send me these papers as well merc vito alternator
johnbollard
ireland
vito 111 cdi
could you send me a copy of these as well , thanks
jbec-john
I'm sorry to drag up an old thread, but I'm about to undertake this job and I was wondering if there's any information still flying around regarding changing the alternator and belt? Ordinarily I'd just get cracking, but the guy who recently fixed my black death problems told me it was a nightmare of a job, so I'm hoping to minimise the pain :eek:D
My email should be in my profile if required.
Thanks in advance for any info.
John
Yes I can send it to you :D:D
jbec-john
Much appreciated fine sir :D
Can you see my email, or do you need me to MSG you with it?
Edit: It's a 2001 112Cdi diesel by the way. I forgot to say.
I cannot use that Email as I cannot attach things.
You can pop it up here early one evening and then delete it within 4 hours
jbec-john
Well, my web address is
jbelectrical.co.uk
And my name is john. Add an @ in the middle and you won't go far wrong :D
OK I have sent it :D
