Vito Black Death ?
ian mckenzie
Preston , Lancashire
2013 E300 hybrid diesel estate
Hi All
I have a 2009 Vito 111 LWB , has an issue whereby the cabin fills up with fumes as soon as van started . Runs well enough , has a slight ticking although still goes well for a 111 . On inspection it appears that on removing the plastic cover that goes over the injectors it has/had black death issue on no 4 injector , can't see any fumes coming from injectors , although it appears to be looking diesel from no 4 injector area . Any thoughts would be appreciated . Thanks
PS when warm it can often take longer to start as though air in system
Jim2
1st Merc 2010 E Class W212 2.1 CDI. 2nd Merc 2014 E Class W212 220 CDI 3rd Merc 2018 E class W213
OBD scan, and definitely identify the exact cause(s)
Mark A
Aberdeen
58 ML-320CDI.
The fumes will be coming from the leaking injector. I would get the leak fixed by a decent indi before doing anything else. Plenty of good how to’s on here if you do fancy a challenge.
poor starting will most likely be air getting into the system, again plenty of good reading on here. The seals go brittle and leak, a pretty cheap fix.
MinionBob
SouthWest
Viano - 2012 - OM651 Engine - 2.2
If it were me, I'd be getting all x4 injector seals replaced and the injectors cleaned/tested while they are out too.
If you just fix the faulty one, special magic will happen and in April, another seal will fail... another in May....
I
ian mckenzie
Stands to reason as the one that is playing up is the least accessible one , have done job on a C220 although access was never an issue on that !
I
ian mckenzie
Just an update on this , on stripping down found to have the dreaded black death on number 4 injector . Other 3 seemed fine , although I have removed and fit new copper washers as a matter of course . Number 4 was an absolute pig to get out , did eventually come out after several hours of persuasion . Only issue I am having now is cleaning up the bolt hole as due to the amount of the tar build up quite a bit went down the bolt hole and is proving a nightmare to clean out . The original bolt will go in so far but will lock up with about 5mm to go . Any advice would be appreciated .
MinionBob
SouthWest
Good job. I presume No 4 was at the back of the engine, closest to the cabin?
Have you tried running a tap with a taper (so not a blind tap) or sharpen the end of a bolt and run it up & down the hole gently to see if the tip of it will pierce and break up the tar at the bottom? Only other ideas I have is to pour an alkali chemical in there like oven cleaning gel and wait for it to work...
I
ian mckenzie
Hi I have tried running one of the old bolts down with a slot cut in it , not sure about a tap as such a long bolt . I sprayed some carb cleaner into the hole last night so hopefully might have some effect .
