el_Pirata
- Dec 19, 2022
- Vito/2010/2.1l diesel
Hi all, this is my first post. I hope I've put it in the right place.
My 2010 Vito was chuffing on cylinder 4. I removed 1, 2 and 3 easily. 4 didn't want to shift. By then, working at -8°C, the engine was cold. So, I thought to replace 1 to 3, run till hot, and work quickly having had practice run. I had some cheap replacement stretcher bolts as well as MB real deal. Since they can only be used once, I figured I'd use the cheap ones, then replace. All fine till cylinder 4. Clamping down the 4th stretcher bolt has stripped the first 3 turns. Realising it was not good I stopped. The cheap bolt was the culprit.
Where to go now? Injector 4 still stuck, thread damaged, engine cold. I assume the rocker cover must come off to tap the thread, but injector stuck...
Help please.
Help please.
