Vito Steering Rack
A
Andy Brown
New to the site!
Does anyone know the size of the oil seal on the pinion ( from steering column) on a 1998 vito sterering rack ? I need the van permenantly at the moment but if I knew the seal size I could order one and change it one weekend without serious loss of the van!!!! Does anyone supply a universal joint for the joint between steering column and rack? Merc just supply a complete column! There is no play whatsoever in the rack but the seal has just started to weep.
Thanks.
Andy Brown.
A
Andy Brown
  • #2
Steering rack oil seal.
Removed steering rack and got the size and number from the seal!
I/D 20mm O/D 44mm and guess what its a special!!!
They can be ordered though, so maybe this info will aid someone in the same situation.
