Alan Marburg
- Sep 20, 2018
- 2004 Vito W639 115 CDi
Have recently had Ignition Module repaired ; Steering Lock repaired, and a used ECU re-programmed - all VIN coded.
Do not have any of the Combination Switch functions working, nor the horn. OBDII says : Fault Code B 1107 N10 [ SAM ] Fault or defect in CAN communication Also Code B 1023 in History says error in CAN communication. Have checked all fuses and connections. Have tried another Combination Switch.
Question : Where do I find the SAM ? When I find the SAM, how can I determine which wire or connector is at fault.
Additional info : Battery light is on - only been on since ECU was re-programmed - new Alternator installed, but no change. Fuel Gauge steadily fluctuates after about 10 minutes from cold start - have not checked the sensor yet.
