frogdr1ver
- Aug 27, 2021
- Vito W639 2011
A few weeks ago the van died, checked the fault code and P0087 was the one listed. I've always been a bit suspect about the in tank fuel pump so replaced that and the fuel filter. Van started up no problem, ran for a couple of weeks and a few hundred miles then died again on Saturday. Just scanned it and same fault code. So looking for suggestions on where to go next. I've heard about the fuel rail pcv going faulty but can that be checked or is it just a replacement job. Would checking the spill back lines on the injectors identify if there is a fault. The only other thing I've carried out on the fuel system in the past was removing an injector due to black death but that was months ago. I did use a third party replacement spill back kit. Would air getting in the return line cause low pressure in the fuel rail?
