Hello can anyone help
I am installing a Sat Nav that needs a permanent 12 Volt feed to it.
Where would I be able to pick this feed up from. If it is from the fuse box how do I connect my cable into it
I think that you need a switched live,, it cannot be an all time live,,you need it so that it works while parked (key1) and when driving (key 2) Can you please check on this,,if the above is correct then the cigar lighter is a good easy place. If it does require a memory back up all time live,then the most convenient place is to tap into the main light feed and use an inline fuse to go to the memory back up
As usual you are correct Malcom. I nee a feed that come live with the switch one on the ingnition. Would you know how I can tap into the cigar lighter feed
can you send me the instructions as i need a switched live feed and need to get to the back of the cigaratte lighter for this and cannot see how to do this thanks
WE HAVE NOW MOVED: 8 Hazel Road, Woolston, SO19 7GB Service, Repairs and remapping service Any queries, please do not hesitate to contactEmail@mbsofsouthampton.co.ukor alternatively you can phone Colin or Dave on 02380 445820, out of hours numbers are 07787913313 or 07907631681.
