W 210 Screen Washers
muzzere320
I’m having a bit of trouble with the windscreen washer jets. Three of the four nozzles are blocked and the one that is working produces a pathetically weak flow.
I’ve has a go at clearing them without success and also tried to remove the “Modules” from the bonnet but can’t see how they come off and I don’t want to force them
Any one had this problem /shed some light??
brandwooddixon
Wolverhampton
S63 Coupe 2014
I'm not sure really, but don't they clip on?
I'll have a look at mine later and see for myself.
hmang
also check that the pipes are well connected to the jet assys.
lift bonnet and get a friend to actuate washers while you watch for leaks underneath
Parrot of Doom
Manchester
Lift the bonnet and access them from underneath. The pipes that feed the nozzles have a habit of popping off. Simple job.
Some pictures here
muzzere320
That's a great help I'll have a go on Sunday
