turnipsock said:You then need to work out what jets you need after that, I would err on the lean side with the way that petrol prices are going.
turnipsock said:Probably not, but here goes...
lean mixture has less petrol/more air therefore you don't use as much petrol. You don't produce as much power though and excessive leaning can cause damage to valves and pistons.
