W116 350SE won't start
Chazchuzzlewitt
Dorchester
W/S124 320TE Estate
hasn't been run for about 1.5 weeks, radio + lights work (dim) but starter will not engage. I can hear the starter solenoid click but the starter motor does not fire and engine does not turn.
Tried jumping it from my diesel but had no effect. Motor started fine previously. help!
Hello Chaz, turn the headlamps on, and try the starter, if the headlights go out its battery, if they stay on and you get the click from motor when you turn the key,it will be the starter motor at fault, give it a whack with a hammer, may be just brushes stuck or worn.
Malcolm
Chazchuzzlewitt
Chazchuzzlewitt
Dorchester
W/S124 320TE Estate
cheers, turned out to just be flat battery-swapped it with the one from my 124 and it started fine :)
johnnycapone
Morecambe
It is usually a flat battery, but as Malcolm suggested some times the starter sticks and you have to give it a whack.
Regards
John
www.W140.co.uk&www.r129.co
