w123 300d leak
shivayash
My car is leaking oil, its pink! Its coming from the engine or gearbox?
Its pretty clean - and I have noticed the autobox gear changing being a little harsh. Its leaking more and more as each day passes. Any ideas?
Many thanks,
barrymarie
hi,sounds like auto-transmission fluid,needs sorting a.s.a.p. good luck
shivayash
how can i go about fixing this? or best taking it to a mechanic?
Parrot of Doom
Manchester
You need to drive the car onto ramps (or jack up onto axle stands) and find out where the leak is first.
wireman
lancashire
Your power steering also has the pink stuff in it, examine the steering box and the pipes that run from it to the engine mounted pump.
