W123 buyers advice would be lovely - 300TD 1979
SamCritch
Amsterdam, Netherlands
www.a2b.cc
W123 buyers advice anyone? 300TD 1979
This weekend I'm planning to go and see a 1979 300TD that's for sale within an hour or so of where I live (in Amsterdam). It looks to be in good condition from the 3 photos on the website, and I'll be quizzing the owner about it in detail.
I used to own a W111 (1966 230S) and ran (and fixed) a Peugeot 305 diesel for several years, but I don't have any experience specific to this model or Mercedes diesels, so I could do with some tips for problems to look out for. Any volunteers?
I've been reading the forums and have come up with areas which seem commonly to be a problem. If you have any more, I'd be really interested in hearing about them. Here we go:
Engine, Transmission, Suspension
  • - Watch out for worn timing chain
  • - - Is wear visible? Or is the chain behind a cover?
  • - - I will ask when it was last changed. What's the recommended interval?
  • - Watch out for valve seals
  • - - How do I detect wear here? White smoke?
  • - Head gaskets - these go occasionally
  • - Leaking joint between engine and injection pump
  • - If the engine starts well from cold, then it's usual in good condition (?)
  • - Warm idling ticking sound is common
  • - - What does this signify?
  • - Doesn't seem like smoke is a big problem with these engines
  • - Watch out for corrosion around battery tray
  • - Look out for smooth gear change with no slip
  • - If rear suspension is stiff, hydraulic spheres may need replacing
  • - Listen for worn out differential
  • - - How to detect? Noise when cornering?
Bodywork, Interior etc
  • - Most common places for rust
  • - - Lower front arches
  • - - Rear wheel arches
  • - - Inner plastic wheel arch protectors (not sure what these will look like)
  • - - Valances (lower front)
  • - - Bottom of boot window and boot door
  • - - - Open boot and look closely under window with a torch
  • - - Sills
  • - - Front wings (how to check inside?)
  • - - Underneath
  • - - Check bulkhead (how to access?)
  • - - Around sunroof
  • - Leaky sunroof
  • - - Very common
  • - - Usually caused by clocked drains (these run to the sills)
  • - - Check for pipe corrosion if possible
  • - Wet under front passenger carpet
  • - - Usually blocked sunroof drains (again)
  • - Driver's seat side-support cushion usually worn
  • - Central locking often not working properly any more
  • - - Usually down to broken/leaking vacuum hose somewhere
  • - - Vacuum comes from manifold
  • - Headlight adjusters
  • - - Again, usually vacuum-related again
  • - Economy gauge
  • - Seat belts - rear seats and seats 6 & 7 sometimes stuck
Electrics
  • - No one seems to have a problem with these!
Anything else?
Many thanks in advance,
Sam
Froddan
Vacuum related, central locking usually runs out of pressure in a day or so. Can still open the door but it won't open all of them, until engine is started.
www.ckinsurance.co.uk
