Not altogether familiar with the diesels but I thout that the 5 cylinder was the 300. Mercedes usually cast into the surface of the head the size of engine. This can be under the rocker cover. The first 3 digits of the engine number found on the block are the engine series.
The engine would be a 3ltr version. Engine number I think stamped on the face of the block at the side of the inlet manifold where the cylinder head meets the block. Should start with 617.
