w123 indicators not working - any ideas....
taylor20
1984 230E
The indictors (which work off the indicator/wiper switch) have just stopped working. The switch still works the wipers, full headlight beam etc BUT will not 'click' in the indictors. Also the Hazard warning lights will not flash. ANY SUGGESTION please - I don't think it's a fuse (as having looked the fuse is for the brake lights too - which work). Could it be a loose wire/earth OR is a new conmtrol stick needed... Thanks :confused::confused:
I think from memory that the relay for this is in the center console
T
taylor20
1984 230E
many thanks will try this weekend - do you know what sort of price new ones are......
These things are not that expensive,,you could get one from robparker a member here
T
taylor20
1984 230E
Great!! looked at this at the week-end. Looked under centre console and found that the conector had come loose!! nice easy fix and most important didnt cost anything.
Thanks for pointers....
Pleased that it worked out well,,,good cars the 123
