Hey all.
I'm a mechanical novice - want to learn.
Recently my friend noticed a small fuel leak from one of my injectors (the one closest the firewall, and hence the driver)
Each injector has the fuel supply in the center, with two overflow nipples either side.
Each injector is daisy chained via the nipples with the rubber overflow pipes, and said pipes then lead back to the fuel pump.
But the injector closest to the driver has the closest nipple simply closed by a smalll rubber blanking piece.
This is split, and has now been fixed with pvc tape.
Is this layout normal - should I have an injector without 2 nipples on it on the closest cylinder to the driver?
Can I just bodge this bit of rubber back together?
thank you alll. I am posting under the influence of beer. Hope it's clear.
Dan
Dan
