CharlesJones
- Nov 2, 2010
- 1982 Mercedes W123 230E Saloon, and a 1984 Porsche 911 Coupe.
Hi All,
The throttle pedal on my 1982 w123 230E doesn't even come close to the kickdown switch - there is a good half inch or so gap with the pedal fully pressed. I have taken a look at the throttle linkages on the engine side, and as far as I can tell they all look okay, with no excessive slop or play which I can see. I can't find any pedal travel adjustment on the pedal side either.
What I am wondering is if I have a piece missing between kickdown switch and pedal. The switch itself looks somewhat naked, and there is such a distance between it and the pedal that I'd be surprised if that gap could be made up by throttle linkage adjustment.
I have attached a picture of what my kickdown switch looks like - the first picture is with the carpet down, and the next with the carpet pulled out of the way. The carpet isn't obstructing the pedal, by the way.
If you have a car of a similar year please could you take a quick glace under your throttle pedal and let me know if your kickdown switch looks the same as mine, or does it have some sort of attachment slipped over it?
Also, if you know of a way to adjust the travel of the throttle pedal please can you let me know?
Many thanks for your help,
Charles.
Charles.
