W124 +2 seatbelts locked
3ps
I managed to replace a window regulator today and was pleased with myself so decided to have a go at installing the +2 seats in my W124 300TD.
I have removed all the trim. I have installed the seat base and back and the seat belt receivers.
I am trying to install the belt reels. I can see that they are mounted "inside" the wheel arch. i can line up the bolt and the positioning clip.
But the belt will not reel out. At first I though it had to be in the perfect position to work, but even when bolted in it isn't working.
I got 2 used belts and both are the same. The car came with 1 used belt and it too won't work.
So I assume I have to do something to release them rather than all 3 being broken??????
Thanks for any advice.
Bolide
www.w124.co.uk
BMW 525 Diesel Touring
The reels are "handed" so they only fit on one side
If you look at the reels they'll have markings like X-0 degrees and Y-320 degrees. Those are the angles the reel has to be mounted at for the belt to withdraw. I always check them before fitting - hold them up in the correct orientation and they'll work. A couple of degrees out and they won't. It'll take you 5 minutes to work out the first one
Make sure you have all the bolts & washers correct for the belts & reels - the washers are essential for the correct load capacity of the bolts
Nick Froome
www.w124.co.uk
3ps
I saw those markings but haven't gotten them to work. I opened up the cover and could see the ball bearing... took it out and it was still locking. Occassionally I could get it to free up but once I stopped moving it it would lock again.
I had a third belt which worked perfectly so I think I have 2 duds :( Merc dealers are chargin EUR120+VAT per side which is a bit hard to stomach TBH.
Do you/anyone have an link to a pic of what bolts and washers go where so I can double check please?
