W124 230E
Status
Not open for further replies.
adel
I just bought my 230E 1991.
Reading the owner manual I found out that I can close both front electric window when I am locking the driver door by keeping the door key in the lock position for couple a second.
My electric sunroof should close as well with the front window if is tilt open, but every time I am using this brilliant feature my sunroof tilt open (if is shut) or stay open (if opened).
The system work perfect with my front window but it works the opposite way with my sunroof.
Any help how to solve this problem will be appreciated.
Thank you,
NormanB
Portsmouth UK
Although I own a similar vehicle and have this feature - I am no expert on it.
But from first principles.
If your sunroof operates correctly when using the direct control inside the car, as far as opening,close and tilt. Then the problem may be with the 'Comfort or Convenience' relay (I forget the name).
May be an expert will jump in here and help us both out!!
Good luck
NormanB
PS: I hardly ever use this feature myself.
igh
Hi - had the same trouble. Fix is simple but expensive if it goes wrong so .... at your own risk. In the boot on the nearside behind the panel you will find the sunroof motor. Using the key as you describe, shut the windows (roof is open?) Adjust roof with hexagonal nut on motor using a socket. Bingo - hopefully!
igh
Status
