Will I need to install a pump injector? I heard you need to install a pump injector for a RWD, mine's a LWD.It is possible to add a turbo charger to pretty much any engine.
But consider you would need to source a suitable turbo charger (volume/speed etc)
Build an exhaust manifold and tubing.
Select an appropriate wastegate
Construct an intake manifold
Consider building an intercooler
Design and install oil lines and return for the turbo ensuring sufficient pressure
Select and install new injectors
Then most likely new pistons, rings, bearings and maybe Conrods.
Need to ensure fuel pump delivers sufficient fuel for new injectors.
If you are comfortable with all that then it's easy.
Otherwise not so much
Sent from my ONEPLUS A5010 using Tapatalk
