Can anyon eplease help with this problem? Intermittent shutdown of the engine. There is no warning at all, and no obvious pattern as to when this occurs, ie it makes no difference wnether the car is waiting in a traffic quue, moving slowly, or cruising quickly. Equally this has happened both during warmup when the engine is fairly cold and also when the engine is fully warmed up during a lengthy drive. The loss of the engine is sudden and total; it is not total loss of electrics in the car because all the normal warning lights appear on the dashboard; equally I am not convinced it is a fuel flow issue as there is no evidence of rough running prior to shutdown as might be the case if fuel flow was poor. In a similar way, it is unlikely to be partial loss of cylinders problem as there is no lumpy running as would be the case if one or more cylinders had failed. Just prior to the problem occurring, the engine is running normally; when th eproblem occurs normal cold and hot start porocedures do not work, I just have to wait up to four minutes then the engine restarts as though nothing had happened and runs perfectly normally until the next occurrence which may be an hour later, a day later, or a week later. Very frustrating - can anyone please offer any advice? Replies please to paul_fi_jackson@lineone.net
