MotardMan
- Apr 3, 2003
- Location
- Berkshire, UK
- 1995 E320T, S124, W124, Sportline
Since buying this car, it has blown the top hose off the rad, and now the oil cooler is leaking slightly. The rad hose blew off due to the top jubilee clip being over tightened in the past, the rad has a plastic "snout" for the hose to fit over, and it fractured spewing the coolant all over the road... There is enough of the "snout" to fit the hose back on, but I will have to replace the rad soon..
The leaking cooler is another problem. Anyone who has removed this item: can you let me know if any O rings, copper washers or special parts are required for refitting it? The CD manual I have does not cover th removal and refit of this cooler, so I am worried I will not be able to make it oil tight on reassembly. Any tips for removal BTW?
Best,
Jim
Best,
Jim
