John Turner
- May 20, 2002
- S124 250TD (1989), S124 E300TD (1995), S211 E320 cdi Sport (2007)
I have a 1995 W124 300 diesel estate (606 engine). I have diesel leaking from a small hole in the shaft of the shut off valve on top of the fuel filter on start up. The car has twice failed to start, requiring 2 batteries worth of cranking. I have received some excellent advice regarding replacement of o rings in fuel hoses, and possibly even the plastic hoses and their connectors, but am not yet convinced that these are the problem. I suspect the shut off valve is the problem, but apparently replacement is expensive (£65) and, unless seated well, may cause running on after replacement. It may be that the o rings which should be changed when the fuel filter is changed are shot, but these and the filter were only changed last year during a main dealer service. Can anyone advise whether the hole in the shut off valve shaft is some sort of bleeder hole, and fuel leaking here is indicative of another problem, or whether simply replacing the o rings will solve the problem? I obviously do not want to replace the fuel shut off valve (how can it be so expensive?), or start on the hoses and o rings if the problem has a more simple solution. Any help much appreciated (& apologies to anyone who has responded on the other place form!)
John
John
