rayhennig
- Nov 16, 2006
- 1991 300CE-24 Sportline
A break in the +ve (positive) supply has been verified and, currently, the +ve supply is being taken from the right hand supply. Of course, the warning light shines brightly on the dashboard.
So, I must find where the cable (pink/grey, I think) is broken. It's likely to be somewhere near the boot hinge but it is far from easy to get to the cables without tearing into insulation and conduit..
Does anyone know where the cables run to once they enter the car having passed through the hinge. I need to establish if the supply is good before the hinge. Basically, I want to narrow down the location of the break before I start cutting into insulation.
My hope is that I may be able to draw the cables out, having soldered a flexible cable to one end, find the break, fix it and then draw the cable back using the flexible cable. Then reattach the terminals and all should be fine.
So, please, any insight would be much appreciated.
Thanks in advance and best to all.
RayH
RayH
