W124 300D drivetrain vibration at 1500rpm
petermerle
Capetown, South Africa
My recently acquired 1987 300D ( manual ) has this very harsh drivetrain vibration at about 1500 rpm ( 30km/h in 3rd , 40-50 km/h 4th and 55- 60 km/h ) when slightly loading the engine. It does not do this when in neutral or when vehicle is freehweelin at these speeds. Couplings are good and engine /gearbox mounts have been replaced to no avail. There is however no propshaft vibration damper on the car - ( not sure if there should be ?? ) - could this be the problem. Merc don not sell the vibration damper for this model - I suspect it comes with a complete new propshaft. Any suggestions
Peter
240D 3.0VNTi
Federal Heights, Colorado USA
Thats called lugging. You should keep the engine speed above 2000rpm when you are moving in gear. These aren't truck engines with a 2800rpm redline, they need RPMs to make power.
P
petermerle
its not lugging - You can load engine at 1200 rpm it does not complain , at 1500 it hits a resonance peak - My 3 OM617 5 cylinder vehicles do not do this , its defininetly feels like some uncontrolled torsional vibration.
IS this vehicle supposed ( 300D manual ) to have the vibration damper ? EPC says part does not exist , however I suspect it comes part of the driveshaft.
PEter
I would check the prop shaft u/j's and bearings as black says, the engine mounts could also do it if worn as it puts the drive chain out of line
