Leylandp76
I recently bought an E reg 300TE (12 valve model) with 164K miles. The car has no service history as it was a recent dealer trade-in. Mechanically it seems OK and although not 100%, not bad for its age cosmetically.
I've probably done 2000 miles in it, mostly motorway. Last night I was stopped in heavy traffic for a while (not for the first time) and the idle started to get quite rough. When I moved away there was a bad misfire, but under hard accelleration the misfire went away.
The misfire returned again after another slow section, to such an extent that I could barely accelerate out of an uphill junction. Once again, it cleared with a bit of a rev, but returned (not quite as badly) quite soon after.
I stopped the car, left the motor running, and checked under the bonnet. I checked the radiator cap first - no excess pressure there, or steam/heat etc. I checked the oilcap and there is a slight vacuum as you would expect. Apart from the miss, nothing obviously wrong. No rattling, knocking etc. After I switched off the motor I also checked the oil level and it is fine.
The motor did not get hot at all, and has shown no tendency to get hot since I have had it. I am careful about checking oil and water levels as well.
Any ideas? I'm worried it's a headgasket on the way out, but is this symptomatic of problems others have had? Any help appreciated...
thanks
Alistair
thanks
Alistair
